Product pictures do not show in frontend. HTTP issue.
JakubŽídek
Post by JakubŽídek » 09 Jan 2022, 16:29
Hello, when I create a product in the backend and add a picture to it I can see the picture in the backend no problem.
However in the frontend I get an error:
Mixed Content: The page at 'https://my.page.com/shop/ProductsCategory~4' was loaded over HTTPS, but requested an insecure image 'http://my.page.com/preview/6/8/688d4432_464039551.jpg'. This request has been blocked; the content must be served over HTTPS.
If I browse to the http://my.page.com/preview/6/8/688d4432_464039551.jpg or http://my.page.com/preview/6/8/688d4432_464039551.jpg it shows the image without problems either way.
APP_URL in .env is correctly set to HTTPS.
THANK YOU
Re: Product pictures do not show in frontend. HTTP issue.
Post by aimeos » 09 Jan 2022, 16:38
JakubŽídek
Post by JakubŽídek » 10 Jan 2022, 09:03
Thank you for your reply.
In the src/default.php file I have the following:
Where do I set the ASSET_URL if I want to use that instead of the config('app.url')?
Thank you so much.
Post by aimeos » 11 Jan 2022, 08:44
You have an old Aimeos version. Which one do you use?
Check in config/app.php what the "url" configuration is set to. If it's APP_URL and the APP_URL setting in the .env file is correct, make sure you clear the cache:
php artisan aimeos:clear
Or disable caching during development:
https://github.com/aimeos/aimeos-laravel#hints
JakubŽídek
Post by JakubŽídek » 13 Jan 2022, 11:03
That did it!
I had the whole row missing in .env
Thank you!
