apply PercentRebate for all products
viptapis
Post by viptapis » 12 Jan 2022, 23:26
Hello
for the PercentRebate it must add percentrebate.productcode -> https://tinyurl.com/yyeg95vq
which will be for specific Product (SKU)
what if i want to apply the coupon for all products?
Please advice
Vip
Re: apply PercentRebate for all products
Post by aimeos » 13 Jan 2022, 14:26
The product code should be the SKU of a product you create in the product panel as which represents the line in the basket with the rebate amount. It has nothing to do with limiting the rebate to a specific product.
Look here for reference:
https://aimeos.org/docs/latest/manual/c ... centrebate
viptapis
Post by viptapis » 13 Jan 2022, 14:41
Hello
thanks for your reply,
yes i understand that i have to add sku.
but i want to give rebate to all products in the panel, not specific SKU.
anyway for give fix % discount for all products?
Regards
Vip
Post by aimeos » 13 Jan 2022, 14:45
aimeos wrote: 13 Jan 2022, 14:26 It has nothing to do with limiting the rebate to a specific product.
Please read
viptapis
Post by viptapis » 16 Jan 2022, 13:56
Hello
its so great, Thanks for you explanation,
I tried to find the use of below functions in documents, but i couldn't find:
percentrebate.precision
percentrebate.roundvalue
https://tinyurl.com/ycmwtepw
would you explain the use of it.
Regards
Vip
Post by aimeos » 17 Jan 2022, 08:19
We've added documentation for the missing options now:
