Change the main directory
РоманАндрейчук
Post by РоманАндрейчук » 13 Jan 2022, 15:17
I have just installed this ecommerce package.
I have a question about routing. How to remove "shop/" from url? There will be only one store on the site.
Example:
http://magic.com/en/shop/Demo-article-5
Should be:
http://magic.com/en/Demo-article-5
I am use Laravel 8*, Aimeos 2021.10*, php 7.3*
Re: Change the main directory
Post by aimeos » 14 Jan 2022, 08:17
You can remove the "shop" prefix from the generated URLs:
- https://github.com/aimeos/aimeos-larave ... op.php#L19
- https://github.com/aimeos/aimeos-larave ... #L194-L249
The problem is that the Laravel login won't work afterwards and you have to find a workaround for that.
АндрейЖидилин
Post by АндрейЖидилин » 27 Apr 2022, 10:03
aimeos wrote: 14 Jan 2022, 08:17 You can remove the "shop" prefix from the generated URLs:
Is there any workaround to get around the admin login issue?
Post by aimeos » 27 Apr 2022, 10:25
In Laravel 9, it should work because the authentication URL changed to /auth/login
