Sitemap Cron Not Working
agatqapp
Post by agatqapp » 15 Jan 2022, 07:12
Hello sir
I want to create sitemap, according to article, i set sitemap base url in shop.php
'controller' => [
'jobs' => [
'catalog' => [
'export' => [
'sitemap' => [
'baseurl' => 'https://www.domain.com/sitemap/',
'location' => 'https://www.domain.com/sitemap/aimeos-sitemap-index.xml',
and set cron job on server
artisan aimeos:jobs "product/export/sitemap"
but its not create sitemap on given path.
Re: Sitemap Cron Not Working
Post by aimeos » 16 Jan 2022, 12:17
The location configuration must be an absolute file system path, no URL.
agatqapp
Post by agatqapp » 17 Jan 2022, 15:48
Yes i also check with absolute file system path, but its not create sitemap
i follow this article https://aimeos.org/docs/latest/config/c ... og-export/
please explain full configuration for sitemap as demo.
Post by aimeos » 19 Jan 2022, 12:38
It should be:
'controller' => [
	'jobs' => [
		'catalog' => [
			'export' => [
				'sitemap' => [
					'location' => '/path/to/application/public/sitemap/',
Replace /path/to/application/ with your real path and make sure the directory /path/to/application/public/sitemap/ exists and is writable.
