Rebate is deducted from Shipping amount
viptapis
Post by viptapis » 17 Jan 2022, 01:10
Hello Dear,
i have 2 issue
1)Rebate is deducted from Shipping amount!
A)The Rebate is 4.09
B)the shipping is 5.9 ->https://ibb.co/TkKrFwh
C)The rebate (4.09 Euro) is deducted from shipping amount -> https://ibb.co/2KgP08b
D)in the invoice also shows same issue -> https://ibb.co/F3zjGZX
2)some times for PayPal payment i got -> Invalid Shipping Total -> https://ibb.co/d5BF138
I'm not sure if its related to point 1 or its different error.
Please advice
Regards
Vip
Re: Rebate is deducted from Shipping amount
Post by aimeos » 18 Jan 2022, 08:54
Which Aimeos version do you use?
Can you show your rebate configuration?
viptapis
Post by viptapis » 18 Jan 2022, 11:44
HEllo
Rebate Configuration -> https://tinyurl.com/ycpyffw2
the version is : 2021.07.*
Regards
Vip
viptapis
Post by viptapis » 18 Jan 2022, 11:51
I also tried add basket-> https://tinyurl.com/y83pc38b
but same problem.
if shipping is 0 then the deduction will be ok (separate) , but if there is shipping, will deduct from shipping.
Regrdas
Post by aimeos » 19 Jan 2022, 12:51
Strange. The rebate product should have a negative price with equals 15% of the original product price.
Version 2021.07 isn't supported any more. Can you please update to 2021.10 LTS and see if the problem is still there?
viptapis
Post by viptapis » 20 Jan 2022, 07:09
Hello
i update the version to 2021.10 but still the problem there !.
Regards
Post by aimeos » 20 Jan 2022, 14:20
We are unable to reproduce the issue locally. Do you have an installation we can check?
