variant attributes for selection not displayed on FE
MikaelNazarenko
Expert
Post by MikaelNazarenko » 17 Jan 2022, 13:32
Hi Aimeos )
When I add variant attributes to selection product - they not displayed on FE inside single product page.. Is it correct behavior ?
Re: variant attributes for selection not displayed on FE
Post by aimeos » 18 Jan 2022, 09:14
Can you post screenshots?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 18 Jan 2022, 10:32
Sure,
Here you see attributes for variants https://prnt.sc/26f439e
And they are displayed on FE https://prnt.sc/26f43s6
And here you see variant attributes for main selection product https://prnt.sc/26f449p
And pink color not shown on FE, only colors from variants are displayed.. The template code I did not change, only css.
MikaelNazarenko
Expert
Post by MikaelNazarenko » 18 Jan 2022, 10:35
My target is something like this: I want to have 2 variants of product. So I want to create selection product and 1 variant product. Then I assign variant attributes for selection and for variant. Then when I go inside product on FE the attributes should be preselected as for selection product, or possible to select attributes from variant... Should it work like this ?
Thank you a lot !
MikaelNazarenko
Expert
Post by MikaelNazarenko » 18 Jan 2022, 10:47
From what I see here ext/ai-client-html/client/html/templates/common/partials/selection-standard.php variant attributes from selection product not used..
MikaelNazarenko
Expert
Post by MikaelNazarenko » 18 Jan 2022, 10:59
Seems such a code is missing in the file I specified above:
foreach ($this->get('productItem')->getRefItems( 'attribute', null, 'variant' ) as $attrId => $attrItem) {
    $attrTypeDeps[$attrItem->getType()][$attrId] = $attrItem->getPosition();
    $attributeItems[$attrId] = $attrItem;
    $attrDeps[$attrId][] = $this->get('productItem')->getId();
    $prodDeps[$this->get('productItem')->getId()][] = $attrId;
with this code from first look it should work..
MikaelNazarenko
Expert
Post by MikaelNazarenko » 18 Jan 2022, 11:08
but now when I choose var attributes from selection product - product is not added to basked. When I choose var attributes from variant product - product is added to basked.. Seems missed something
MikaelNazarenko
Expert
Post by MikaelNazarenko » 18 Jan 2022, 12:15
I did not check deep but seems after adding the following code:
$isSelectionAttrSelected = true;
foreach( $variant as $id )
            if( $productItem->getListItem( 'attribute', 'variant', $id ) === null ) {
                $isSelectionAttrSelected = false;
                break;
if($isSelectionAttrSelected) {
            $items[] = $productItem;
before the line:
foreach( $productItem->getRefItems( 'product', null, 'default' ) as $item )
method getArticle()
in the file /vendor/aimeos/ai-controller-frontend/controller/frontend/src/Controller/Frontend/Basket/Decorator/Select.php
it works. I mean when I select variant attributes from selection product - the product added to basked with correct attributes!
Please look at the code I provided and tell me if it is right solution ?
Thank you !
MikaelNazarenko
Expert
Post by MikaelNazarenko » 18 Jan 2022, 12:20
Sorry forgot specify the components version:
aimeos/ai-admin-jqadm              2021.10.4 Aimeos Vue.js+Bootstrap admin interface
aimeos/ai-admin-jsonadm            2021.10.2 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html              2021.10.5 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi           2021.10.2 Aimeos JSON API extension
aimeos/ai-cms-grapesjs             2021.10.1 Aimeos GrapesJS CMS extension
aimeos/ai-controller-frontend      2021.10.2 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs          2021.10.3 Aimeos ai-controller-jobs extension
aimeos/ai-gettext                  2021.10.1 Aimeos Gettext extension
aimeos/ai-laravel                  2021.10.1 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer              2021.10.1 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                 2021.10.6 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel              2021.10.3 Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
aimeos/map                         2.4.0     Easy and elegant handling of PHP arrays as array-like map objects similar to jQuery and Laravel Collections
MikaelNazarenko
Expert
Post by MikaelNazarenko » 18 Jan 2022, 12:44
I don't understand now how to extend /vendor/aimeos/ai-controller-frontend/controller/frontend/src/Controller/Frontend/Basket/Decorator/Select.php this decorator
