Variations stocks removed
eljacko
Post by eljacko » 07 Feb 2022, 14:51
"php": "^7.3|^8.0",
"aimeos/aimeos-laravel": "~2021.10",
"laravel/framework": "^8.75",
Hi, i have a product with a lot of variations. I have added unlimited stock to each variation. When i save the "main" product, all the variations stocks are removed from the database. What am i doing wrong?
EDIT: Is there a way to set unlimited stock in the main product, variations tab in the stock field?
Re: Variations stocks removed
Post by aimeos » 08 Feb 2022, 10:49
If you leave the stock level field of the variant articles empty and add a stock entry for the parent product with unlimited stock, then the variant articles should have also unlimited stock levels.
eljacko
Post by eljacko » 08 Feb 2022, 16:34
I have tried that, but then it says out of stock when selecting a variant.
Post by aimeos » 10 Feb 2022, 15:51
Problem is fixed. If the stock level field for variant articles is empty, it's treated as unlimited stock now.
To update your installation, please execute:
composer req aimeos/ai-admin-jqadm:2021.10.x-dev
developer
Post by developer » 09 Dec 2022, 16:14
Hi Aimeos,
I have facing same problem but i don't want to update version. Because I have do many custom code that might be effected.
Can you please le me know the line of code update for the same? and where I can add that code?
Your help will be save my time.
