Remove "/shop"
ritesh
Remove "/shop"
Post by ritesh » 25 Feb 2022, 11:02
I want to remove the "/shop" path from the routes "/{site}/shop" and make it just "/{site}"; which works perfectly if I remove it from routes in shop config. But I also have other pages for example: "/about-us" which throws an exception -- about-us is being taken as site-code.
No item found for conditions: Array ( [locale.site.code] => about-us )
Here's my route array on shop config
'routes' => [
     'jsonapi' => ['prefix' => '{site}/jsonapi', 'middleware' => ['web', 'api']],
     'account' => ['prefix' => '{site}/profile', 'middleware' => ['web', 'auth']],
     'default' => ['prefix' => '{site}', 'middleware' => ['web']],
What am I missing here? I have tried statically configuring the default prefix, overwriting the aimeos shop routes and the both solution has it's flaws and errors.
_______
Laravel 8 with Aimeos 2021.10 + Marketplace. Setup via composer. Mac with Valet and MySql 8.0.25
Re: Remove "/shop"
Post by aimeos » 26 Feb 2022, 07:56
The Laravel routes which matches "/about-us" must be before the route for "/{site}". If "/about-us" should be matched dynamically by "/{page}", then it's impossible to define a routing that will work.
One option is to use a subdomain or custom domain for "{site}" so "{page}" can match all non-matched URLs at the end.
ritesh
Re: Remove "/shop"
Post by ritesh » 28 Feb 2022, 11:15
"/about-us" is basically a static page with a custom route that is already on the top of the routes on routes/web.php file. Or am I missing something?
Re: Remove "/shop"
Post by aimeos » 01 Mar 2022, 09:07
Laravel doesn't support ordering routes very well and the only way to be sure that the correct route is used is to make it the only one matching that URL.
