Issue after updating from 2021.07 to 2021.10
ritesh
Post by ritesh » 25 Feb 2022, 11:31
I recently updated the aimeos laravel from 2021.07 to 2021.10, and on home page + other pages that doesn't have {site} parameter on the URL throws and exception:
Illuminate\Routing\Exceptions\UrlGenerationException
Missing required parameter for [Route: aimeos_shop_jsonapi_options] [URI: {site}/jsonapi/{resource?}] [Missing parameter: site].
When I add "?site=default" on the URL then it works. I had to create a middleware that modifies the request and inserts the site parameter manually but now I realized it's not working for file requests for eg: "/fonts/poppins/poppins-v15-latin-regular.woff"
Re: Issue after updating from 2021.07 to 2021.10
Post by aimeos » 26 Feb 2022, 08:00
Yes, you need to add a value for "site" because your routes require it due to the "{site}/" part.
You shouldn't use a middleware to add the site code but just create a redirect from "/" to "/default" for example.
ritesh
Post by ritesh » 28 Feb 2022, 07:26
Is there an aimeos configuration or any other option to set the site code so I don't have to add the query parameters to the URL? Client doesn't want the ?site=default hanging on the end of the URL.
Laravel 8 with Aimeos 2021.10 + Marketplace. Setup via composer. Mac with Valet and MySql 8.0.25
Post by aimeos » 01 Mar 2022, 08:53
In multisite environments, the "site" must be part of the URL but it don't have to be "&site=default". Instead, you can use:
- yourdomain.com/<site>/shop with redirect of "/" to "/default/shop"
- <site>.yourdomain.com/shop
- yourdomain.com/shop, otherdomain.com/shop, etc.
See: https://aimeos.org/docs/latest/laravel/ ... he-routing
