Can anyone tell me how can we extend Base class
skydev
Post by skydev » 01 Mar 2022, 07:40
Can anyone tell us how can we extend base class
FYI: We are using aimeos 2020.10
basically we want to modify
getTaxRates
method available at
Aimeos\Client\Html\Common\Client\Summary\Base class
We try to extend it with Decorator but unable to do can
Can anyone help below is client config code
'html' => [
        "common"=>[
          "client"=>[
              "summary"=>[
                  "decorators"=>[
                      "local"=>class_basename(\Aimeos\Client\Html\Common\Client\Summary\Decorator\SummaryDecorator::class)
Re: Can anyone tell me how can we extend Base class
Post by aimeos » 02 Mar 2022, 07:28
In OOP, it's not possible to replace base classes and as the methods in the base class are protected, you can't use decorators either (they require public methods). The only way to replace these methods is to overwrite the classes that extend from it but this is thedios and you have to duplicate the code.
In dev-master, we've move that code to the order base item which is much easier to replace with an own implementation:
https://github.com/aimeos/aimeos-core/b ... #L784-L848
skydev
Post by skydev » 02 Mar 2022, 07:44
@aimeos thanx for this info
Is there any other way through which we can extend
getTaxRates
method extended ?
Post by aimeos » 02 Mar 2022, 08:00
Like said, only by extending from the classes that extend from the base class themselves and configuring these classes to be used instead of the original ones.
skydev
Post by skydev » 02 Mar 2022, 09:10
Okay @aimeos
We want to tax should exclude discount amount for example
we have created a plugin that says buy 10 pay for 8 but want to include the tax on 10 product (right now it apply on 8 product total)
can you please give us any idea for this
Post by aimeos » 03 Mar 2022, 09:20
The easiest way might be to create a decorator attached to the basket and checkout components which overwrites the "summaryNamedTaxes" key assigned to the template by the components with your own computed value.
