Removing Address Section from Checkout
MattWoodward
Post by MattWoodward » 18 Mar 2022, 05:51
Hi there,
Today I have identified how to remove the Address section (but keep all others incl. Delivery where custom providers will be used) from the Checkout process (and submitted a PR for the docs, as the subparts listed for the configuration was incorrect - https://github.com/aimeos/aimeos-docs/pull/41).
However when I remove the Address subpart I get the error:
"Class "\Aimeos\Client\Html\Checkout\Standard\Order\Standard" not available"
I suspect this is logical, yet I need to exclude the address section. Is this in relation to also needing to remove the address from the Summary section too?
Re: Removing Address Section from Checkout
Post by aimeos » 18 Mar 2022, 08:05
What's your used configuration?
MattWoodward
Post by MattWoodward » 22 Mar 2022, 04:08
Thanks for responding. The following config is in place for this:
	'client' => [
		'html' => [
			'checkout' => [
				'subparts' => ['delivery', 'payment', 'summary', 'order', 'process'],
Post by aimeos » 22 Mar 2022, 06:46
"order" is not a valid subpart (it had been used in earlier versions) and the standard configuration is:
https://github.com/aimeos/ai-client-htm ... d.php#L114
MattWoodward
Post by MattWoodward » 23 Mar 2022, 00:43
Ahh perfect, I've removed that from the config and all is working fine now.
I've also submitted a PR for a change to the docs on this - https://github.com/aimeos/aimeos-docs/pull/42
