Account creation on checkout
MikaelNazarenko
Expert
Post by MikaelNazarenko » 29 Mar 2022, 06:04
Hi Community !
Maybe somebody faced with need to implement customer account autocreation with sending link to set password when user checkout process ?
Maybe somebody did some steps for it ?
Are there in aimeos some built in functions for that ?
SORRY! I noticed there is checkbox in checkbox in checkout to create account. But seems doesn't work.. I don't see new user in DB in users and mshop_customer tables.. Or should I execute some cli command for that ?
Best regards, thanks !
Re: Account creation on checkout
Post by aimeos » 29 Mar 2022, 06:31
That's already built into Aimeos since the beginning.
MikaelNazarenko
Expert
Post by MikaelNazarenko » 29 Mar 2022, 10:00
Yes, sorry for this misunderstanding.
But I notice seems error in aimeos code:
https://github.com/aimeos/ai-controller ... rd.php#L96
$this->item = $item->setPassword( $password );
I guess should be:
$this->item = $this->item->setPassword( $password );
Post by aimeos » 29 Mar 2022, 10:05
You are right, this doesn't set the password correctly and it should be:
Can you create a PR to fix the problem?
