Pass variable to all email templates
MikaelNazarenko
Expert
Post by MikaelNazarenko » 29 Mar 2022, 16:09
Hi Aimeos!
Is it possible to pass variable to all email templates? I tried to add decorator but it doesn't work..
Here is decorator:
namespace Aimeos\Controller\Jobs\Common\Decorator;
class CustomDecorator extends Base
    protected $partialHelper;
    public function __construct(\Aimeos\Controller\Jobs\Iface $controller, \Aimeos\MShop\Context\Item\Iface $context, \Aimeos\Bootstrap $aimeos)
        parent::__construct($controller, $context, $aimeos);
        $view = $context->getView();
        $view->settings = 324234;
        $view->addHelper('partial', $this->getPartialHelper($view));
    protected function getPartialHelper(\Aimeos\MW\View\Iface $view)
        if(!$this->partialHelper) {
            $this->partialHelper = new \Aimeos\Controller\Jobs\Common\Helper\Partial\Partial($view);
        return $this->partialHelper;
Partial:
class Partial extends \Aimeos\MW\View\Helper\Partial\Standard
    public function transform(string $file, array $params = []): string
        $view = $this->getView();
        $params['settings'] = 234234342;
        dd(76567);
        return parent::transform($file, $params);
but settings variable not accessable in email templates (
Re: Pass variable to all email templates
Post by aimeos » 30 Mar 2022, 13:54
This doesn't work because the emails are not generated using partials which are only a way to include the output from another template.
You can create a HTML client decorator and implement the addData() method which then adds your settings to the passed view like described here: https://aimeos.org/docs/latest/frontend ... omponents/
The configuration to apply the decorator to ALL HTML clients (not only for the email ones) would be:
client/html/common/decorators/default = ['Mydecorator']
