Indexes of page array from shop.php
kartikbhat
Post by kartikbhat » 02 Apr 2022, 11:37
'page' => [
	'basket-index' => [ 'basket/bulk', 'catalog/tree', 'catalog/search', 'basket/standard', 'basket/related' ]
part of config/shop.php file,
what these 'basket/bulk' , 'catalog/tree', 'catalog/search', 'basket/standard' ,'basket/related'
components indicates ?
where to locate these things in the package ?
please do suggest me to locate this
Re: Indexes of page array from shop.php
Post by aimeos » 04 Apr 2022, 10:22
These are the components that are available and maps to the HTML client classes here:
https://github.com/aimeos/ai-client-htm ... lient/Html
kartikbhat
Post by kartikbhat » 04 Apr 2022, 14:14
If I want create more custom pages then?
I will create a new index under shop.php under page 'index'
then I will create respective folder under templates folder
then am I able to call/fetch data from database at php files created src/Client/Html using Laravel syntax ?
then how can load this custom pages using route ? where I need to write those routes ?
Provide me these information
TIA :)
Post by aimeos » 06 Apr 2022, 09:48
If you want to create custom pages, you should use Laravel controller actions directly and fetch the data of your custom tables using Eloquent. You usually don't need the abstraction of Aimeos for data that is only relevant for your project.
