Access Managers in Laravel Controller
kartikbhat
Post by kartikbhat » 06 Apr 2022, 18:03
I need to access those Managers which handles 'products' into my Custom Laravel Controller ; How can I fetch list of products from database ;
$manager = \Aimeos\MShop::create( $this->getContext(), 'product' );
this chunk is not working inside of laravel controller;
Help me access products list within my Laravel Controller
TIA :)
Re: Access Managers in Laravel Controller
Post by aimeos » 08 Apr 2022, 06:40
Use this code to get the context in Laravel:
$context = app( 'aimeos.context' )->get();
Please read the documentation too:
https://aimeos.org/docs/latest/laravel/ ... os-objects
kartikbhat
Post by kartikbhat » 08 Apr 2022, 08:00
How Can I fetch active siteid from session in Laravel Controller to utilize it to fetch other related data from database;
TIA
Post by aimeos » 11 Apr 2022, 10:09
If you use the Aimeos frontend controllers or managers, the current site ID is automatically used.
Otherwise, you can get the site ID that way:
$context->locale()->getSiteId()
