Display Variables in blade files
kartikbhat
Post by kartikbhat » 08 Apr 2022, 14:39
How can I display these fetched products data on .blade.php files ?
$products = \Aimeos\MShop::create( $context, 'product' );
Suggest me how Can I loop it and fetch logo, supplier info from these....
TIA
Re: Display Variables in blade files
Post by aimeos » 11 Apr 2022, 10:11
Blade files are just PHP files with additional syntax and you can use the same code as in the Aimeos PHP templates:
https://github.com/aimeos/ai-client-htm ... l/body.php
