how to get a list of all stores
ahmed31916
Post by ahmed31916 » 15 Apr 2022, 06:27
How can I get the list of all stores and it's details
Re: how to get a list of all stores
Post by aimeos » 16 Apr 2022, 08:11
You have a multi-site setup? If yes, you can use the locale/site manager to get a list of all sites:
$manager = \Aimeos\MShop::create( app( 'aimeos.context' )->get() );
$items = $manager->search( $manager->filter() );
These are the available methods of the locale/site items:
https://github.com/aimeos/aimeos-core/b ... /Iface.php
ahmed31916
Post by ahmed31916 » 17 Apr 2022, 10:24
thanks, it works.
But, I wonder there are a lot of config files. Which of them can be relied upon?
Post by aimeos » 18 Apr 2022, 07:59
The ./config/shop.php will always OVERWRITE setting from extension config files and extension config files can ADD settings to core config files.
