error when aimeos setup
ahmed31916
Post by ahmed31916 » 22 Apr 2022, 13:18
I clone my aimeos shop project to another computer. The composer update done perfectly, BUT when I tried to setup aimeos by this command: "php artisan aimeos:setup", I get this error:
SQLSTATE[42S02]: Base table or view not found: 1146 Table 'women_store.madmin_log' doesn't exist:
INSERT INTO "madmin_log" (
"facility", "timestamp", "priority", "message", "request", "siteid"
) VALUES (
["core\/sql","2022-04-22 13:01:46",7,"Time: 9.1660022735596ms\nClass: Aimeos\\MShop\\Locale\\Manager\\Language\\Standard\nSELECT \nmlocla.\"id\" AS \"locale.language.id\", mlocla.\"label\" AS \"locale.language.label\",\nmlocla.\"status\" AS \"locale.language.status\", mlocla.\"mtime\" AS \"locale.language.mmlocla.\"id\" ASC\nLIMIT 2147483647 OFFSET 0","91eeaf0f398b5ccb69776ed16383d1b9",""]
aimeos version: 2022.04
Re: error when aimeos setup
Post by aimeos » 22 Apr 2022, 20:08
Can you post your complete output?
ahmed31916
Post by ahmed31916 » 23 Apr 2022, 02:13
Initializing or updating the Aimeos database tables for site "default"
Migrate type columns
  Add new type columns
    Checking table "mshop_attribute":
    Checking table "mshop_attribute_list":
    Checking table "mshop_attribute_property":
    Checking table "mshop_catalog_list":
    Checking table "mshop_customer_list":
    Checking table "mshop_customer_property":
    Checking table "mshop_media":
    Checking table "mshop_media_list":
    Checking table "mshop_media_property":
    Checking table "mshop_plugin":
    Checking table "mshop_price":
    Checking table "mshop_price_list":
    Checking table "mshop_product":
    Checking table "mshop_product_list":
    Checking table "mshop_product_property":
    Checking table "mshop_service":
    Checking table "mshop_service_list":
    Checking table "mshop_stock":
    Checking table "mshop_supplier_list":
    Checking table "mshop_tag":
    Checking table "mshop_text":
    Checking table "mshop_text_list":
  Drop old unique indexes
    Checking index "unq_msattr_sid_dom_cod_tid":
    Checking index "unq_msattli_sid_dm_rid_tid_pid":
    Checking index "unq_msattpr_sid_tid_lid_value":
    Checking index "unq_mscatli_sid_dm_rid_tid_pid":
    Checking index "unq_mscusli_sid_dm_rid_tid_pid":
    Checking index "unq_mcuspr_sid_tid_lid_value":
    Checking index "unq_msmedli_sid_dm_rid_tid_pid":
    Checking index "unq_msmedpr_sid_tid_lid_value":
    Checking index "unq_msplu_sid_tid_prov":
    Checking index "unq_msprili_sid_dm_rid_tid_pid":
    Checking index "unq_msproli_sid_dm_rid_tid_pid":
    Checking index "unq_mspropr_sid_tid_lid_value":
    Checking index "unq_msserli_sid_dm_rid_tid_pid":
    Checking index "unq_mssto_sid_pcode_tid":
    Checking index "unq_mssupli_sid_dm_rid_tid_pid":
    Checking index "unq_mstag_sid_dom_tid_lid_lab":
    Checking index "unq_mstexli_sid_dm_rid_tid_pid":
  Migrate typeid to type
  Drop typeid columns
Clear property "key" columns
Creating attribute schema
Creating cache schema
Creating catalog schema
Creating CMS tables
Creating coupon schema
Creating customer schema
Creating media schema
Creating price schema
Creating product schema
Update property "key" columns
  Checking table users_property
Creating service schema
Creating supplier schema
Creating text schema
Update lists "key" columns
  Checking table mshop_attribute_list
  Checking table mshop_catalog_list
  Checking table mshop_customer_list
  Checking table mshop_media_list
  Checking table mshop_price_list
  Checking table mshop_product_list
  Checking table mshop_service_list
  Checking table mshop_supplier_list
  Checking table mshop_text_list
Update Laravel lists "key" columns
  Checking table users_list
Creating locale schema
Add locale data for languages and currencies
  Adding data for MShop locale languages
   Aimeos\Base\DB\Exception
                                ) VALUES (
                        ["core\/sql","2022-04-23 02:14:26",7,"Time: 1.0368824005127ms\nClass: Aimeos\\MShop\\Locale\\Manager\\Language\\Standard\nSELECT \nmlocla.\"id\" AS \"locale.language.id\", mlocla.\"label\" AS \"locale.language.label\",\nmlocla.\"status\" AS \"locale.language.status\", mlocla.\"mtime\" AS \"locale.language.mtime\",\nmlocla.\"editor\" AS \"locale.language.editor\", mlocla.\"ctime\" AS \"locale.language.ctime\"\nFROM \"mshop_locale_language\" mlocla\nWHERE 1 = 1\nORDER BY mlocla.\"id\" ASC\nLIMIT 2147483647 OFFSET 0","ecdb725d38fcf31c6303a761a42b4ca8",""]
  at C:\xampp\htdocs\WomenStore\vendor\aimeos\aimeos-base\src\DB\Statement\DBAL\Prepared.php:77
     73▕        {
     74▕                try {
     75▕                        $result = $this->exec();
     76▕                } catch( \Doctrine\DBAL\Driver\Exception $e ) {
  ➜  77▕                        throw new \Aimeos\Base\DB\Exception( $e->getMessage() . ': ' . $this->sql . json_encode( array_column( $this->binds, 0 ) ), $e->getCode() );
     78▕                }
     79▕
     80▕                return new \Aimeos\Base\DB\Result\DBAL( $result );
     81▕        }
  1   C:\xampp\htdocs\WomenStore\vendor\aimeos\aimeos-core\src\MAdmin\Log\Manager\Standard.php:294
      Aimeos\Base\DB\Statement\DBAL\Prepared::execute()
  2   C:\xampp\htdocs\WomenStore\vendor\aimeos\aimeos-core\src\MShop\Common\Manager\Base.php:108
      Aimeos\MAdmin\Log\Manager\Standard::saveItem(Object(Aimeos\MAdmin\Log\Item\Standard))
Post by aimeos » 23 Apr 2022, 19:43
Is there a complete stack trace available too (after the last two lines of output)?
ahmed31916
Post by ahmed31916 » 24 Apr 2022, 07:27
No
Post by aimeos » 26 Apr 2022, 07:35
Can you execute "php artisan -vvv aimeos:setup"? Maybe this reveals the remaining stack trace.
