Set the necessary parameter values in my own action
ahmed31916
Post by ahmed31916 » 23 Apr 2022, 08:36
What if I tried to set the necessary parameter values in my own action like this:
$this->object()->data( $this->view(), $this->tags, $this->expire );
what is
$this->object()
refers to?
Re: Set the necessary parameter values in my own action
Post by aimeos » 23 Apr 2022, 19:49
If you add a decorator to an object which wraps the object, you get an onion-like structure, e.g.:
SomeDecorator (
    MyDecorator (
        Myclass
The "$this->object()" returns the inner object (if called from MyDecorator, it will return MyClass) and you pass the parameters you got in your method down to the next object.
ahmed31916
Post by ahmed31916 » 24 Apr 2022, 07:34
How can I do if "myclass" is a blade file "myclass.blade.php"?
in another words, how to set these parameters in "myclass.blade.php" by the action?
Post by aimeos » 25 Apr 2022, 10:56
Assign your variable in the addData() method to the view object (which is an adapter to the blade view):
https://aimeos.org/docs/latest/frontend ... s/#example
