After installation, all links are broken front and back end
waelm70
Post by waelm70 » 24 Apr 2022, 10:21
Please need help about what i might be missing during installation, trying for 1 week but always same issue, all links are broken.
Installed on online server:
http://vps-6df594a6.vps.ovh.net/myshop/public/
.env File:
APP_URL=http://vps-6df594a6.vps.ovh.net/myshop/pubilc/
ASSET_URL=http://vps-6df594a6.vps.ovh.net/myshop/pubilc/
Laravel: 9.9.0
PHP : 8.1.4
Server: Linux, Apache2, Debian 11
Aimeos version: installed from:
https://github.com/aimeos/aimeos
wget https://getcomposer.org/download/latest ... poser.phar -O composer
php composer create-project aimeos/aimeos myshop
I tried all solutions on forums but didn't find the right one.
Thank you in advance for your help
Here below the "composer show" maybe it's usefull:
aimeos/ai-admin-jqadm 2022.04.3 Aimeos VueJS+Bootstrap admin backend
aimeos/ai-admin-jsonadm 2022.04.1 Aimeos JSON admin API for backend
aimeos/ai-client-html 2022.04.4 Aimeos standard HTML frontend
aimeos/ai-client-jsonapi 2022.04.1 Aimeos frontend JSON REST API
aimeos/ai-cms-grapesjs 2022.04.2 Aimeos GrapesJS CMS extension
aimeos/ai-controller-frontend 2022.04.3 Aimeos business controller logic for frontend
aimeos/ai-controller-jobs 2022.04.3 Aimeos job controllers for long running tasks
aimeos/ai-laravel 2022.04.2 Laravel adapter for Aimeos e-commerce integration
aimeos/aimeos-base 2022.04.1 Aimeos base layer for abstracting from host enviro...
aimeos/aimeos-core 2022.04.4 Full-featured e-commerce components for high perfo...
aimeos/aimeos-laravel 2022.04.2 Professional, full-featured and high performance L...
aimeos/macro 1.0.0 Dynamically extend objects by custom methods
aimeos/map 3.0.1 Easy and elegant handling of PHP arrays as array-l...
aimeos/upscheme 0.8.1 Database schema upgrades made easy
brick/math 0.9.3 Arbitrary-precision arithmetic library
dflydev/dot-access-data v3.0.1 Given a deep data structure, access data by dot no...
doctrine/cache 2.1.1 PHP Doctrine Cache library is a popular cache impl...
doctrine/dbal 3.3.5 Powerful PHP database abstraction layer (DBAL) wit...
doctrine/deprecations v0.5.3 A small layer on top of trigger_error(E_USER_DEPRE...
doctrine/event-manager 1.1.1 The Doctrine Event Manager is a simple PHP event s...
doctrine/inflector 2.0.4 PHP Doctrine Inflector is a small library that can...
doctrine/instantiator 1.4.1 A small, lightweight utility to instantiate object...
doctrine/lexer 1.2.3 PHP Doctrine Lexer parser library that can be used...
dragonmantank/cron-expression v3.3.1 CRON for PHP: Calculate the next or previous run d...
egulias/email-validator 3.1.2 A library for validating emails against several RFCs
enshrined/svg-sanitize 0.15.4 An SVG sanitizer for PHP
facade/ignition-contracts 1.0.2 Solution contracts for Ignition
fakerphp/faker v1.19.0 Faker is a PHP library that generates fake data fo...
filp/whoops 2.14.5 php error handling for cool kids
fruitcake/php-cors v1.2.0 Cross-origin resource sharing library for the Symf...
graham-campbell/result-type v1.0.4 An Implementation Of The Result Type
guzzlehttp/guzzle 7.4.2 Guzzle is a PHP HTTP client library
guzzlehttp/promises 1.5.1 Guzzle promises library
guzzlehttp/psr7 2.2.1 PSR-7 message implementation that also provides co...
hamcrest/hamcrest-php v2.0.1 This is the PHP port of Hamcrest Matchers
laminas/laminas-diactoros 2.9.2 PSR HTTP Message implementations
laravel/breeze v1.9.0 Minimal Laravel authentication scaffolding with Bl...
laravel/framework v9.9.0 The Laravel Framework.
laravel/sail v1.13.10 Docker files for running a basic Laravel application.
laravel/sanctum v2.15.1 Laravel Sanctum provides a featherweight authentic...
laravel/serializable-closure v1.1.1 Laravel Serializable Closure provides an easy and ...
laravel/tinker v2.7.2 Powerful REPL for the Laravel framework.
league/commonmark 2.3.0 Highly-extensible PHP Markdown parser which fully ...
league/config v1.1.1 Define configuration arrays with strict schemas an...
league/flysystem 3.0.17 File storage abstraction for PHP
league/mime-type-detection 1.11.0 Mime-type detection for Flysystem
mockery/mockery 1.5.0 Mockery is a simple yet flexible PHP mock object f...
monolog/monolog 2.5.0 Sends your logs to files, sockets, inboxes, databa...
myclabs/deep-copy 1.11.0 Create deep copies (clones) of your objects
nesbot/carbon 2.57.0 An API extension for DateTime that supports 281 di...
nette/schema v1.2.2 📐 Nette Schema: validating data structures agai...
nette/utils v3.2.7 🛠 Nette Utils: lightweight utilities for strin...
nikic/php-parser v4.13.2 A PHP parser written in PHP
nunomaduro/collision v6.2.0 Cli error handling for console/command-line PHP ap...
nyholm/psr7 1.5.0 A fast PHP7 implementation of PSR-7
phar-io/manifest 2.0.3 Component for reading phar.io manifest information...
phar-io/version 3.2.1 Library for handling version information and const...
php-http/message-factory v1.0.2 Factory interfaces for PSR-7 HTTP Message
phpdocumentor/reflection-common 2.2.0 Common reflection classes used by phpdocumentor to...
phpdocumentor/reflection-docblock 5.3.0 With this component, a library can provide support...
phpdocumentor/type-resolver 1.6.1 A PSR-5 based resolver of Class names, Types and S...
phpoption/phpoption 1.8.1 Option Type for PHP
phpspec/prophecy v1.15.0 Highly opinionated mocking framework for PHP 5.3+
phpunit/php-code-coverage 9.2.15 Library that provides collection, processing, and ...
phpunit/php-file-iterator 3.0.6 FilterIterator implementation that filters files b...
phpunit/php-invoker 3.1.1 Invoke callables with a timeout
phpunit/php-text-template 2.0.4 Simple template engine.
phpunit/php-timer 5.0.3 Utility class for timing
phpunit/phpunit 9.5.20 The PHP Unit Testing framework.
psr/cache 3.0.0 Common interface for caching libraries
psr/container 2.0.2 Common Container Interface (PHP FIG PSR-11)
psr/event-dispatcher 1.0.0 Standard interfaces for event handling.
psr/http-client 1.0.1 Common interface for HTTP clients
psr/http-factory 1.0.1 Common interfaces for PSR-7 HTTP message factories
psr/http-message 1.0.1 Common interface for HTTP messages
psr/log 3.0.0 Common interface for logging libraries
psr/simple-cache 3.0.0 Common interfaces for simple caching
psy/psysh v0.11.2 An interactive shell for modern PHP.
ralouphie/getallheaders 3.0.3 A polyfill for getallheaders.
ramsey/collection 1.2.2 A PHP library for representing and manipulating co...
ramsey/uuid 4.3.1 A PHP library for generating and working with univ...
sebastian/cli-parser 1.0.1 Library for parsing CLI options
sebastian/code-unit 1.0.8 Collection of value objects that represent the PHP...
sebastian/code-unit-reverse-lookup 2.0.3 Looks up which function or method a line of code b...
sebastian/comparator 4.0.6 Provides the functionality to compare PHP values f...
sebastian/complexity 2.0.2 Library for calculating the complexity of PHP code...
sebastian/diff 4.0.4 Diff implementation
sebastian/environment 5.1.4 Provides functionality to handle HHVM/PHP environm...
sebastian/exporter 4.0.4 Provides the functionality to export PHP variables...
sebastian/global-state 5.0.5 Snapshotting of global state
sebastian/lines-of-code 1.0.3 Library for counting the lines of code in PHP sour...
sebastian/object-enumerator 4.0.4 Traverses array structures and object graphs to en...
sebastian/object-reflector 2.0.4 Allows reflection of object attributes, including ...
sebastian/recursion-context 4.0.4 Provides functionality to recursively process PHP ...
sebastian/resource-operations 3.0.3 Provides a list of PHP built-in functions that ope...
sebastian/type 3.0.0 Collection of value objects that represent the typ...
sebastian/version 3.0.2 Library that helps with managing the version numbe...
spatie/backtrace 1.2.1 A better backtrace
spatie/flare-client-php 1.1.0 Send PHP errors to Flare
spatie/ignition 1.2.9 A beautiful error page for PHP applications.
spatie/laravel-ignition 1.2.2 A beautiful error page for Laravel applications.
symfony/console v6.0.7 Eases the creation of beautiful and testable comma...
symfony/css-selector v6.0.3 Converts CSS selectors to XPath expressions
symfony/deprecation-contracts v3.0.1 A generic function and convention to trigger depre...
symfony/error-handler v6.0.7 Provides tools to manage errors and ease debugging...
symfony/event-dispatcher v6.0.3 Provides tools that allow your application compone...
symfony/event-dispatcher-contracts v3.0.1 Generic abstractions related to dispatching event
symfony/finder v6.0.3 Finds files and directories via an intuitive fluen...
symfony/http-foundation v6.0.7 Defines an object-oriented layer for the HTTP spec...
symfony/http-kernel v6.0.7 Provides a structured process for converting a Req...
symfony/mailer v6.0.7 Helps sending emails
symfony/mime v6.0.7 Allows manipulating MIME messages
symfony/polyfill-ctype v1.25.0 Symfony polyfill for ctype functions
symfony/polyfill-intl-grapheme v1.25.0 Symfony polyfill for intl's grapheme_* functions
symfony/polyfill-intl-idn v1.25.0 Symfony polyfill for intl's idn_to_ascii and idn_t...
symfony/polyfill-intl-normalizer v1.25.0 Symfony polyfill for intl's Normalizer class and r...
symfony/polyfill-mbstring v1.25.0 Symfony polyfill for the Mbstring extension
symfony/polyfill-php72 v1.25.0 Symfony polyfill backporting some PHP 7.2+ feature...
symfony/polyfill-php80 v1.25.0 Symfony polyfill backporting some PHP 8.0+ feature...
symfony/polyfill-php81 v1.25.0 Symfony polyfill backporting some PHP 8.1+ feature...
symfony/process v6.0.7 Executes commands in sub-processes
symfony/psr-http-message-bridge v2.1.2 PSR HTTP message bridge
symfony/routing v6.0.5 Maps an HTTP request to a set of configuration var...
symfony/service-contracts v3.0.1 Generic abstractions related to writing services
symfony/string v6.0.3 Provides an object-oriented API to strings and dea...
symfony/translation v6.0.7 Provides tools to internationalize your application
symfony/translation-contracts v3.0.1 Generic abstractions related to translation
symfony/var-dumper v6.0.6 Provides mechanisms for walking through any arbitr...
tecnickcom/tcpdf 6.4.4 TCPDF is a PHP class for generating PDF documents ...
theseer/tokenizer 1.2.1 A small library for converting tokenized PHP sourc...
tijsverkoyen/css-to-inline-styles 2.2.4 CssToInlineStyles is a class that enables you to c...
vlucas/phpdotenv v5.4.1 Loads environment variables from `.env` to `getenv...
voku/portable-ascii 2.0.1 Portable ASCII library - performance optimized (as...
webmozart/assert 1.10.0 Assertions to validate method input/output with ni...
Re: After installation, all links are broken front and back end
Post by aimeos » 25 Apr 2022, 10:57
The ./public/ directory must be the document root of your domain. It can't be a subdirectory of your domain.
waelm70
Post by waelm70 » 25 Apr 2022, 11:01
Thank you very much. I missed this.
Just fixed it with htaccess file
Have a nice day
