Error after update Adding product with ID is not allowed
DevTarget
Post by DevTarget » 25 Apr 2022, 11:29
Hello
i have
OS: window 10
"php": "^7.2",
"aimeos/ai-payments": "^2021.01",
"aimeos/aimeos-laravel": "~2021.01",
"laravel/framework": "^6.2",
i do a update for aimeos
"aimeos/aimeos-laravel": "~2020.04" to "~2021.01",
everything works except basket, i have this error "Adding product with ID 19 is not allowed" ?
can someone help me please?
Thanks for your answer.
Re: Error after update Adding product with ID is not allowed
Post by aimeos » 26 Apr 2022, 07:56
This error is usually the result if the product is not attached to any category:
https://github.com/aimeos/ai-controller ... ry.php#L53
DevTarget
Post by DevTarget » 26 Apr 2022, 08:37
but the product id datadase is affected to a category in table mshop_index_catalog.
Thanx
Post by aimeos » 26 Apr 2022, 08:41
Is this also the case after you execute:
php artisan aimeos:jobs index/rebuild
DevTarget
Post by DevTarget » 26 Apr 2022, 08:51
Hello
the command deletes the list in the table mshop_index_catalog but does not solve the problem.
Post by aimeos » 28 Apr 2022, 05:31
If the record from mshop_index_catalog is deleted, then there's no catalog relation in the mshop_product_list table. Note that one of the biggest changes between 2021 and 2022 versions is that the category<->product relations moved from mshop_catalog_list to mshop_product_list table. The setup tasks should migrate them automatically.
