Your requirements could not be resolved to an installable set of packages.
- АндрейЖидилин
Hello
When I try to install the theme, I get the following error:
It turns out that there is no extension for aimeos-laravel 2022.x? How to be in this case?
Problem 1
- Root composer.json requires aimeos-themes/fromukraine dev-dev1-62602 -> satisfiable by aimeos-themes/fromukraine[dev-dev1-62602].
- aimeos-themes/fromukraine dev-dev1-62602 requires aimeos/aimeos-laravel ~2021.07 -> found aimeos/aimeos-laravel[2021.07.1, ..., 2021.10.x-dev] but it conflicts with your root composer.json require (~2022.04).
Use the option --with-all-dependencies (-W) to allow upgrades, downgrades and removals for packages currently locked to specific versions.
You can also try re-running composer require with an explicit version constraint, e.g. "composer require aimeos-themes/fromukraine:*" to figure out if any version is installable, or "composer require aimeos-themes/fromukraine:^2.1" if you know which you need.
Installation failed, reverting ./composer.json and ./composer.lock to their original content.
Re: Your requirements could not be resolved to an installable set of packages.
Sorry, we are lagging behind the releases with some tasks for various reasons.
The extension builder is now up to date and can create extensions for the new 2022 versions.
The documentation will be updated soon.
- АндрейЖидилин
Super!aimeos wrote: 29 Apr 2022, 06:13 Sorry, we are lagging behind the releases with some tasks for various reasons.
It's great that you are so quick to resolve user requests.
Starting to fall in love with your product
