Decorators / Components for selected themes
krzysiekp
Post by krzysiekp » 09 May 2022, 17:04
How to do to create different decorators for different shops. It is a multishop application.
For example. For one shop I have one decorator:
client/html/catalog/lists/decorators/global = ['Mydecorator']
but for another shop I have:
client/html/catalog/lists/decorators/global = ['MydecoratorNew']
How to configure it ?
And for example
packages\new-theme\client\html\templates\checkout\confirm\body-standard.blade.php
will change in the second store.
Is it possible to set one theme for two stores, but in one of them the layout
will change ?
Re: Decorators / Components for selected themes
Post by aimeos » 11 May 2022, 06:28
krzysiekp wrote: 09 May 2022, 17:04 How to do to create different decorators for different shops. It is a multishop application.
You can use the Option/Value table for setting different configuration options per site in the Locale > Site panel, e.g.:
client/html/catalog/lists/decorators/global/MydecoratorNew : MydecoratorNew
krzysiekp wrote: 09 May 2022, 17:04 And for example
will change ?
If the templates should be different, the best option is to use two different themes. If it's only one template, you can use the Option/Value table for the site to set an alternative template, e.g. for a "body-custom.blade.php":
client/html/templates/checkout/confirm/template-body : checkout/confirm/body-custom
