Decorator get no result
ahmed31916
Post by ahmed31916 » 13 May 2022, 07:44
I'm trying to add new data to the view object required by the product template, (from my extension).
I create decorator path "myextension\src\Client\Html\Common\Decorator\my_product_decorator.php", and put this code in it:
namespace Aimeos\Client\Html\Common\Decorator;
class my_product_decorator
            extends \Aimeos\Client\Html\Common\Decorator\Base
            implements \Aimeos\Client\Html\Common\Decorator\Iface
    public function data( \Aimeos\Base\View\Iface $view, array &$tags = [], string &$expire = null ) : \Aimeos\Base\View\Iface
        $view = parent::data( $view, $tags, $expire );
        $view->descripto= 'some description';
        return $view;
and put the "config/shop.php" like this:
	'client' => [
		'common' => [
			'partials' => [
				'product' => [
					'decorators' => [
						'global' => 'my_product_decorator',
Now, I'm trying to get the value of the "descripto" from the decorator, so I add this in "myextension\templates\client\html\common\partials\products.php":
<?= $this->get( 'descripto' ) ?>
At the end, NO result appear. Where is the problem?
ahmed31916
Re: Decorator get no result
Post by ahmed31916 » 13 May 2022, 13:47
@Aimeos
Post by aimeos » 14 May 2022, 07:18
First, you should use another class name like "ProductMyproject" (replace "Myproject" by your project name).
Then, your configuration is wrong and you have to configure the decorator for a component (or all components), e.g.:
	'client' => [
		'html' => [
			'catalog' => [
				'detail' => [
					'decorators' => [
						'global' => ['ProductMyproject'],
https://aimeos.org/docs/2022.x/config/c ... il/#global
ahmed31916
Post by ahmed31916 » 14 May 2022, 08:12
Thanks, I edit it, and got this error: "Aimeos\Base\View\Helper\Partial\Standard::transform(): Argument #1 ($file) must be of type string, array given"
the complete error trace:
https://flareapp.io/share/V7jLOMjm#F65
the config:
	'html' => [
		'common' => [
			'partials' => [
				'products' => [
					'decorators' => [
						'global' => ['ProductWomenTemplate'],
ahmed31916
Post by ahmed31916 » 15 May 2022, 10:49
Unfortunately, the problem is still not resolved.
Post by aimeos » 16 May 2022, 06:38
Remove the configuration because it's wrong:
		'common' => [
			'partials' => [
				'products' => [
					'decorators' => [
ahmed31916
Post by ahmed31916 » 16 May 2022, 07:51
Nothing changed :| .
I want to know is the namespace is correct? and the return value is $view?
and the aregument interface of the function is correct?
        return $view;
Post by aimeos » 17 May 2022, 14:32
Namespace is correct but your configuration is not because "common/partial/products" is now an array but it must be a string. Check again and clear the Laravel config cache if necessary.
ahmed31916
Post by ahmed31916 » 17 May 2022, 20:31
thanks for your response.
would you write a complete config for it, please! (it made me tired)
Post by aimeos » 18 May 2022, 06:07
Like written, the correct configuration is:
	'client' => [
		'html' => [
			'catalog' => [
				'detail' => [
					'decorators' => [
and remove:
		'common' => [
			'partials' => [
				'products' => [
					'decorators' => [
If you want to use different product partials use this instead:
		'common' => [
			'partials' => [
				'products' => 'common/partials/product-woman'
The template file must be in: "templates/client/html/common/partials/product-woman.php"
