Price rules don't work when using product manager
VadimSaratov
Post by VadimSaratov » 17 May 2022, 10:09
I am using aimeos laravel 2021.10.5 and laravel 8.42.1 I created price rules as described in the documentation https://aimeos.org/docs/2021.x/providers/rules/ and the rules work for the JSON API, when displayed in the store, etc. but when I request a product with a price using the manager, the rules do not apply to the price.
should the price rules be applied automatically when requesting through the manager, or should I apply the decorator manually in this case?
my code using manager looks like this:
        $manager = MShop::create(app('aimeos.context')->get(), 'product');
        $product = $manager->get($product_id,
                'attribute',
                'media',
                'price',
                'product',
                'product/property',
                'text',
                'catalog',
                'supplier',
                'stock'
Re: Price rules don't work when using product manager
Post by aimeos » 18 May 2022, 06:19
Price rules are only applied to the frontend, otherwise managing product prices would not be possible. Use the frontend controller instead, which applies the price rules automatically:
https://github.com/aimeos/ai-controller ... d.php#L202
An equivalent example is:
\Aimeos\Controller\Frontend::create(app('aimeos.context')->get(), 'product')
	->uses( [
                'attribute',
                'media',
                'price',
                'product',
                'product/property',
                'text',
                'catalog',
                'supplier',
                'stock'
        ->get( $product_id );
For the available methods, have alook into the interface:
https://github.com/aimeos/ai-controller ... /Iface.php
VadimSaratov
Post by VadimSaratov » 18 May 2022, 07:13
Ok, thanks
