[SOLVED]Access Product attributes after checkout/payment
kartikbhat
Post by kartikbhat » 23 May 2022, 15:19
It is possible to loop basket products after checkout ?
I need to access attributes and their values of specific products after doing checkout; I need to utilize for further different operation; help me to get it;
TIA :)
Re: Access Product attributes after checkout/payment
Post by aimeos » 24 May 2022, 17:19
If the attributes are stored along with the ordered product, you can use:
foreach( $basket->getProducts() as $orderProduct )
	foreach( $orderProduct->getAttributeItems() as $attrItem )
		echo $attrItem->getValue();
Check the interfaces for available methods:
- https://github.com/aimeos/aimeos-core/b ... #L401-L425
- https://github.com/aimeos/aimeos-core/b ... /Iface.php
