how do add captcha to login page?
ttcode
Post by ttcode » 25 May 2022, 12:23
example this packet of captcha.
https://github.com/mewebstudio/captcha
here tuto steps for laravel but for aimeos how i can add this ?
https://www.positronx.io/laravel-captch ... l-example/
thanks in advance
i think aimeos login need more security is good idea captcha or meaby other?
Re: how do add captcha to login page?
Post by aimeos » 26 May 2022, 09:46
Aimeos uses Laravel auth infrastructure incl. the Laravel login/register/etc. forms so you can add the captcha there like described in the links you've posted. There's no interaction with Aimeos when adding the captcha to the Laravel login page.
ttcode
Post by ttcode » 26 May 2022, 12:16
thaks i go try do this
have nice day m8
