change the content helper path
- ahmed31916
- Advanced
This helper, goes to the route "aimeos/path/to/image".
How to remove "aimeos" keyword from the path?
$this->content('path/to/image')Re: change the content helper path
Overwrite the "fs" and "fs-media" file systems in your config/shop.php and adapt the "baseurl" value:
https://github.com/aimeos/aimeos-larave ... hp#L53-L64
- ahmed31916
- Advanced
when I tried to override on the "resource" in the "config/shop.php", I got this error:
full trace:
https://flareapp.io/share/LPdoNdYm#F81
An exception occurred in the driver: SQLSTATE[HY000] [1045] Access denied for user ''@'localhost' (using password: NO)full trace:
Configuration in ./config/shop.php replaces the whole default configuration so you have to add the complete config and change the parts you need:
https://github.com/aimeos/aimeos-larave ... p#L36-L105
