How to extend language file en.po
ahmed31916
Post by ahmed31916 » 31 May 2022, 08:54
I'm trying to overwrite the "en.po" file. I copy the file from the vendor, and paste it inside the path:
"packages\theme2\i18n\currency\en.po". But it didn't accept the translation from this file.
What did I do wrong?
Re: How to extend language file en.po
Post by aimeos » 01 Jun 2022, 05:25
The .po files need to be compiled into the MO file format:
msgmft -o en.po en
See here: https://aimeos.org/docs/latest/developer/translations/
ahmed31916
Post by ahmed31916 » 27 Jul 2022, 08:30
executing this command "msgmft -o en.po en" returns this error message:
'msgfmt' is not recognized as an internal or external command,
operable program or batch file.
OS: windows
Post by aimeos » 28 Jul 2022, 04:55
For Windows, you need the Cygwin environement with the Gettext tools installed.
Alternatively, you can add your translations to your ./config/shop.php file:
https://aimeos.org/docs/latest/laravel/ ... anslations
ahmed31916
Post by ahmed31916 » 28 Jul 2022, 13:16
thanks, I installed poedit program. It converts the .po file. It works.
