get an array of products with it's ID and LABEL
ahmed31916
Post by ahmed31916 » 01 Jun 2022, 10:36
How to get an array of products (or any domain) with it's ID and LABEL?
This get the Label, but how to get it's id?
->getLabel()->toArray()
something like this:
array:3 [
5 => "product1"
7 => "product2"
11 => "product3"
Re: get an array of products with it's ID and LABEL
Post by aimeos » 02 Jun 2022, 10:12
The product IDs are already used as keys in the array.
ahmed31916
Post by ahmed31916 » 02 Jun 2022, 11:22
Thanks for your reply, but maybe you didn't understand my point.
Anyway, is there a function in Aimeos similar to the "where" eloquent function that we use in Laravel?
Post by aimeos » 02 Jun 2022, 11:50
ahmed31916 wrote: 02 Jun 2022, 11:22 Thanks for your reply, but maybe you didn't understand my point.
According to your question, you requested something like:
array(
    <product ID> => '<product label>',
If this is not the case, what do you want instead?
ahmed31916 wrote: 02 Jun 2022, 11:22 Anyway, is there a function in Aimeos similar to the "where" eloquent function that we use in Laravel?
The Map object implemented where() to filter the collection:
https://php-map.org/#where
ahmed31916
Post by ahmed31916 » 02 Jun 2022, 13:00
I wanted array with id and label for sub categories to use it in ajax for main category.
Using getLabel function: " ->getLabel()->toArray()", it get an array with sub categories without id.
When things get tough I used query builder, and it meet the purpose. Thanks.
Post by aimeos » 02 Jun 2022, 13:55
The IDs of the objects are always the keys of the arrays when you get back the collection from the storage.
If you transform data and it's not the case any more, you can always use the "col()" method to rekey the collection, e.g. for a collection of categories:
$collection->col( null, 'catalog.id' )
