Override default aimeos-laravel base.blade.php
Re: Override default aimeos-laravel base.blade.php
aimeos provides a fantastic infrastructure that you can override/ modify or customise everything
. base.blade is just a blade template and laravel theme extenstion have service provider that all you need for laravel service container.. in provider you can use you're own logic how to handel template inside .
https://aimeos.org/docs/2022.x/laravel/ ... -templates
