Get search result for all languages
ahmed31916
Post by ahmed31916 » 06 Jun 2022, 12:48
How to get a result of all languages (not just current langaue)?
$search->make( 'index.text:name', [app()->getLocale()]  )
Does, adding the star solve the problem?
$search->make( 'index.text:name', ['*']  )
Re: Get search result for all languages
Post by aimeos » 07 Jun 2022, 16:16
Searching for product texts independent of a language is not available when using the index manager because the language ID is used here and it's mandatory:
https://github.com/aimeos/aimeos-core/b ... hp#L59-L66
You can overwrite the class and remove from "index.text:relevance" (MySQL example):
public function getSearchAttributes( bool $withsub = true ) : array
	$level = \Aimeos\MShop\Locale\Manager\Base::SITE_ALL;
	$level = $this->context()->config()->get( 'mshop/index/manager/sitemode', $level );
	$expr = $this->siteString( 'mindte."siteid"', $level );
	$list = parent::getSearchAttributes( $withsub );
	$list['index.text:relevance']['internalcode'] = $this->siteString( 'mindte."siteid"', $level ) . ' AND MATCH( mindte."content" ) AGAINST( $2 IN BOOLEAN MODE )';
	return $list;
