User manual issue (add characteristic)
ahmed31916
Post by ahmed31916 » 19 Jun 2022, 10:19
Hello Aimeos,
My website is a car seller, and I want to add a new car. The new car have characteristic for each part, like: engine characteristics, Body characteristics and Transmission characteristics .. etc. how can I add this for the new car?
Re: User manual issue (add characteristic)
Post by aimeos » 20 Jun 2022, 15:21
Are these configurable attributes or just for the customers' information?
ahmed31916
Post by ahmed31916 » 20 Jun 2022, 19:28
yes, it is configurable attributes, I will rely on it later in the searching filter.
Post by aimeos » 21 Jun 2022, 12:42
Add the attributes as configurable attribute to your car product. They should be available in the attribute filter too if you haven't restricted it by configuration.
