Order again from history
MikaelNazarenko
Expert
Post by MikaelNazarenko » 21 Jun 2022, 05:22
Hi Aimeos community !
You know, in personal account we have orders history.
Do you have some solutions or ideas how to integrate function to put all products from specific order to basket just with click and buy them again ?
Thanks !
MikaelNazarenko
Expert
Re: Order again from history
Post by MikaelNazarenko » 21 Jun 2022, 06:30
This is code I use:
        if(\Request::get('his_action') == 'buy-again' && ($his_id = \Request::get('his_id'))) {
            $domains = ['attribute', 'media', 'price', 'product', 'text'];
            /** @var \Aimeos\Controller\Frontend\Basket\Decorator\CustomSelect $basketCntl */
            $basketCntl = \Aimeos\Controller\Frontend::create( $context, 'basket' );
            $productCntl = \Aimeos\Controller\Frontend::create( $context, 'product' )->uses( $domains );
            /** @var \Aimeos\MShop\Common\Manager\Decorator\Depth $orderManager */
            $orderManager = \Aimeos\MShop::create( $context, 'order' );
            /** @var \Aimeos\MShop\Order\Item\Standard $orderItem */
            $orderItem = $orderManager->get( $his_id, ['order/base', 'order/base/address', 'order/base/product', 'order/base/service', 'order/base/product/attr'] );
            /** @var \Aimeos\MShop\Order\Item\Base\Standard $basket */
            $basket = $basketCntl->load( $orderItem->getBaseId() );
            /** @var \Aimeos\MShop\Order\Item\Base\Product\Standard $product */
            foreach ($basket->getProducts() as $product) {
                $attributes = [
                    'variant' => [],
                    'custom' => [],
                    'config' => []
                /** @var \Aimeos\MShop\Order\Item\Base\Product\Attribute\Standard $attributeItem */
                foreach ($product->getAttributeItems() as $attributeItem) {
                    if($attributeItem->getType() == 'variant') {
                        $attributes[$attributeItem->getType()][$attributeItem->getCode()] = $attributeItem->getAttributeId();
                    } elseif($attributeItem->getType() == 'custom') {
                        $attributes[$attributeItem->getType()][$attributeItem->getAttributeId()] = $attributeItem->getValue();
                    } elseif($attributeItem->getType() == 'config') {
                        $attributes[$attributeItem->getType()]['qty'][] = $attributeItem->getQuantity();
                        $attributes[$attributeItem->getType()]['id'][] = $attributeItem->getAttributeId();
                $basketCntl->addProduct( $productCntl->get( $product->getProductId() ),
                    $product->getQuantity(),
                    $attributes['variant'],
                    $this->getAttributeMap( $attributes['config'] ),
                    $attributes['custom'],
                    $product->getStockType(),
                    $product->getSupplierId(),
                    $product->getSiteId()
Maybe will be useful for someone. Any suggestions and improvements are welcome !
Post by aimeos » 21 Jun 2022, 06:40
The feature is already available since 2-3 years:
https://github.com/aimeos/ai-client-htm ... #L329-L368
MikaelNazarenko
Expert
Post by MikaelNazarenko » 21 Jun 2022, 09:20
Wow ! Great !
And is it available in the following version ?
aimeos/ai-client-html              2021.10.5 Aimeos ai-client-html extension
MikaelNazarenko
Expert
Post by MikaelNazarenko » 21 Jun 2022, 09:48
Sorry, my mistake. The function is there. Great !) You can remove this topic )
