Default jqadm view (index.blade.php)
peter69
Post by peter69 » 21 Jun 2022, 21:47
Hello!
I have created a theme (which I have generated with the online tool to generate aimeos themes for laravel).
I have modified the file "index.blade.php" which is located in /packages/my-theme/views/jqadm/ however it is not overwriting/applying the changes.
I did a test by creating the file in /resources/views/vendor/shop/jqadm/ and the changes work there!
How can I get the changes I make in /packages/my-theme/views/jqadm/index.blade.php applied?
Regards,
laravel: 9.2
aimeos-laravel: ~2022.04
PHP: 8.1.6
Environment: Ubuntu 20.04.4 LTS
Re: Default jqadm view (index.blade.php)
Post by aimeos » 24 Jun 2022, 09:54
Views from Laravel theme extensions are only applied if the theme is selected for the current site but the backend doesn't use themes per site yet so there's only the master theme available which you can overwrite by storing the files in ./resources/views/vendor/shop/
