Generating site map job fails, missing site param?
DmS
Post by DmS » 22 Jun 2022, 11:00
Hi. the cronjobs to generate sitemaps fails for us.
The conf is correct but I'm getting "Missing required parameter for [Route: aimeos_shop_detail] [URI: {site}/shop/{d_name}/{d_pos?}/{d_prodid?}] [Missing parameter: site].#0 "
Full backtrace on error:
php artisan aimeos:jobs "product/export/sitemap" "saluhall"
Missing required parameter for [Route: aimeos_shop_detail] [URI: {site}/shop/{d_name}/{d_pos?}/{d_prodid?}] [Missing parameter: site].#0 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Routing/RouteUrlGenerator.php(91): Illuminate\Routing\Exceptions\UrlGenerationException::forMissingParameters(Object(Illuminate\Routing\Route), Array)
#1 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Routing/UrlGenerator.php(466): Illuminate\Routing\RouteUrlGenerator->to(Object(Illuminate\Routing\Route), Array, true)
#2 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Routing/UrlGenerator.php(441): Illuminate\Routing\UrlGenerator->toRoute(Object(Illuminate\Routing\Route), Array, true)
#3 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/ai-laravel/lib/custom/src/MW/View/Helper/Url/Laravel5.php(62): Illuminate\Routing\UrlGenerator->route('aimeos_shop_det...', Array, true)
#4 [internal function]: Aimeos\MW\View\Helper\Url\Laravel5->transform('aimeos_shop_det...', 'catalog', 'detail', Array, Array, Array)
#5 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(88): call_user_func_array(Array, Array)
#6 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/ai-controller-jobs/controller/jobs/templates/product/export/sitemap-items-body-standard.php(38): Aimeos\MW\View\Standard->__call('url', Array)
#7 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(282): include('/Users/dansegol...')
#8 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(264): Aimeos\MW\View\Standard->includeFile('/Users/dansegol...')
#9 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/ai-controller-jobs/controller/jobs/src/Controller/Jobs/Product/Export/Sitemap/Standard.php(133): Aimeos\MW\View\Standard->render('product/export/...')
#10 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/ai-controller-jobs/controller/jobs/src/Controller/Jobs/Product/Export/Sitemap/Standard.php(424): Aimeos\Controller\Jobs\Product\Export\Sitemap\Standard->addItems(Object(Aimeos\MW\Container\Content\Gzip), Object(Aimeos\Map))
#11 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/ai-controller-jobs/controller/jobs/src/Controller/Jobs/Product/Export/Sitemap/Standard.php(55): Aimeos\Controller\Jobs\Product\Export\Sitemap\Standard->export(Object(Aimeos\MW\Container\Directory))
#12 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/JobsCommand.php(54): Aimeos\Controller\Jobs\Product\Export\Sitemap\Standard->run()
#13 [internal function]: Aimeos\Shop\Command\JobsCommand->Aimeos\Shop\Command\{closure}(Object(Aimeos\MShop\Context\Item\Standard), Object(Aimeos\Bootstrap), 'product/export/...')
#14 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Pcntl.php(181): call_user_func_array(Object(Closure), Array)
#15 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Pcntl.php(116): Aimeos\MW\Process\Pcntl->exec(Object(Closure), Array)
#16 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Decorator/Check.php(61): Aimeos\MW\Process\Pcntl->start(Object(Closure), Array, false)
#17 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/JobsCommand.php(63): Aimeos\MW\Process\Decorator\Check->start(Object(Closure), Array, false)
#18 [internal function]: Aimeos\Shop\Command\JobsCommand->Aimeos\Shop\Command\{closure}(Object(Aimeos\MShop\Context\Item\Standard), Object(Aimeos\Bootstrap))
#19 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Pcntl.php(181): call_user_func_array(Object(Closure), Array)
#20 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Pcntl.php(116): Aimeos\MW\Process\Pcntl->exec(Object(Closure), Array)
#21 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Decorator/Check.php(61): Aimeos\MW\Process\Pcntl->start(Object(Closure), Array, false)
#22 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/AbstractCommand.php(67): Aimeos\MW\Process\Decorator\Check->start(Object(Closure), Array, false)
#23 /Users/dansegolson/Documents/code/dinsaluhall/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/JobsCommand.php(69): Aimeos\Shop\Command\AbstractCommand->exec(Object(Aimeos\MShop\Context\Item\Standard), Object(Closure), 'saluhall')
#24 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Aimeos\Shop\Command\JobsCommand->handle()
#25 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#26 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure(Object(Closure))
#27 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Array, Object(Closure))
#28 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Container/Container.php(653): Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), Array, Array, NULL)
#29 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Console/Command.php(136): Illuminate\Container\Container->call(Array)
#30 /Users/dansegolson/Documents/code/dinsaluhall/vendor/symfony/console/Command/Command.php(298): Illuminate\Console\Command->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#31 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Console/Command.php(121): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#32 /Users/dansegolson/Documents/code/dinsaluhall/vendor/symfony/console/Application.php(1015): Illuminate\Console\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#33 /Users/dansegolson/Documents/code/dinsaluhall/vendor/symfony/console/Application.php(299): Symfony\Component\Console\Application->doRunCommand(Object(Aimeos\Shop\Command\JobsCommand), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#34 /Users/dansegolson/Documents/code/dinsaluhall/vendor/symfony/console/Application.php(171): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#35 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Console/Application.php(94): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#36 /Users/dansegolson/Documents/code/dinsaluhall/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(129): Illuminate\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#37 /Users/dansegolson/Documents/code/dinsaluhall/artisan(37): Illuminate\Foundation\Console\Kernel->handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#38 {main}Process (PID "93957") failed with status "256"%
_____________
Laravel 8 with Aimeos 2021.10.7 + Marketplace. Setup via composer. Mac with Valet and MySql 8.0.25
Re: Generating site map job fails, missing site param?
Post by aimeos » 24 Jun 2022, 15:57
The job controller for generating sitemaps did only work if no additional parameter like "site", "locale" and "currency" are required. Now, this has been rewritten and the new code will be part of 2022.07. The relevant changes are:
https://github.com/aimeos/ai-controller ... bea1ed45ad
DmS
Post by DmS » 27 Jun 2022, 07:23
Ah, that explains it.
Thank you
_____________
