[SOLVED] Bring Price added to attribute option using ajax
kartikbhat
Post by kartikbhat » 23 Jun 2022, 07:34
I have created a attribute (eg: flavour) then I have added options to it in backend
  • Orange
  • Mango
  • Choco
created dropdown for this options on my frontend
Here I have added price for each options from backend; like
  • Orange - $5
  • Mango - $6
  • Choco - $7
Now I need to bring price of specific option on select of it from dropdown using AJAX;
Help me to call ajax with proper urls and parameters to be send to it;
TIA :)
Re: Bring Price added to attribute option using ajax
Post by aimeos » 24 Jun 2022, 11:52
If you need to calculate the total price of the product including all selected options before it's added to the basket, you need to sum up the attribute prices using a few lines of custom JS code. The Aimeos JSON API won't give you that value until the article is added to the basket.
