make a new route for a template
ahmed31916
Post by ahmed31916 » 29 Jun 2022, 09:30
Hello Aimeos,
How to make a new route nested from "profile", I have seen helper function "link", but I didn't know how to use it.
Re: make a new route for a template
Post by aimeos » 30 Jun 2022, 12:44
You can use the Laravel route() method in the Aimeos templates too to generate the route by name.
ahmed31916
Post by ahmed31916 » 03 Jul 2022, 11:57
No aimeos, I didn't mean this.
I mean how to make a new route for any domain related to the "profile" for example: "profile/something" and this route should be redirects to favorite page (not to "profile" page)?
I tried to make ("profile/products"), using aimeos way, but the route redirects to index profile page (not a new page).
I tried to making a new route using laravel Route but it makes things a little complicated.
Post by aimeos » 04 Jul 2022, 14:01
You always have to define a new route in Laravel for "/profile/something" because Aimeos uses the Laravel routing implementation. If that works, you can give the new route a name in the ./routes/web.php file (e.g. "profile-something") and use that name as parameter to the route() method.
TEJASPARMAR
Post by TEJASPARMAR » 14 Jun 2024, 07:58
So, we can't define a route within an extension we have created?
Post by aimeos » 14 Jun 2024, 15:59
No, only in the Laravel application itself
