Some conjobs seem not working
marnel
Post by marnel » 07 Jul 2022, 20:56
Hello!
Thanks for your help so far...
I'm building a great e-commerce app thank to Aimeos.
However, I'm dealing with some issues:
1- I set up the cronjob like explained in the doc and I actually get emails when customers make payments.
But they don't receive the email containing their password when they check 'Create a customer account for me'. I asked to receive an email when cronjob failed but I don't receive anything about this one.
Here is how I set the cron :
I executed on the CLI:
crontab -e
Then, I added the line
* * * * * php /absolute/path/to/artisan aimeos:jobs "order/export/csv order/email/delivery order/email/payment order/email/voucher order/service/delivery subscription/export/csv customer/email/account"
Any idea about this that can help me?
2- The cron "product/export/sitemap" also keep falling. As I asked to receive an email when this happen, I keep receiving every day at 00:00 am, an email saying
Missing required parameter for [Route: aimeos_shop_detail] [URI: {locale}/shop/{d_name}/{d_pos?}/{d_prodid?}] [Missing parameter: locale].
How can I provide the parameter 'locale' to the cron, please?
Thanks for your help!
Re: Some conjobs seem not working
Post by aimeos » 08 Jul 2022, 08:57
You cronjob setup seems to be OK for sending account e-mails. Which Aimeos version do you use?
The product sitemap didn't support multiple locales and sites until recently. This feature is available in the latest 2022.07 release.
marnel
Post by marnel » 08 Jul 2022, 16:32
I'm on the 2021.10 version
Post by aimeos » 10 Jul 2022, 07:04
Can you add a debug statement here to see if the job performs any action?
https://github.com/aimeos/ai-client-htm ... rd.php#L74
marnel
Post by marnel » 11 Jul 2022, 01:06
The execution of the following line https://github.com/aimeos/ai-client-htm ... d.php#L135
throws this error:
Missing required parameter for [Route: aimeos_shop_account] [URI: {locale}/profile] [Missing parameter: locale].
It seems it's the same issue as with the "product/export/sitemap" cron :|
Am I the only one having this issue with a multi-language aimeos site?
Post by aimeos » 11 Jul 2022, 06:34
The sitemap job controller supports multi-locale environments only recently (2022.07+)
Did you overwrite the template for the customer account e-mails? In 2021.10, the locale parameter is added to the URL by default:
https://github.com/aimeos/ai-client-htm ... .mjml#L152
marnel
Post by marnel » 11 Jul 2022, 14:50
Actually no, I didn't overwrite any template for the customer account e-mails.
I did some debugging and the mail is sent correctly when I remove this only line: https://github.com/aimeos/ai-client-htm ... rd.php#L34
However, the login button doesn't redirect to the login page anymore.
Post by aimeos » 11 Jul 2022, 15:11
The locale parameter for login has been added in 2022.04 release.
If you want to use a multi-locale setup, maybe it's better to switch to the current 2022.07 release which supports multiple locales in cronjobs much better than before.
marnel
Post by marnel » 11 Jul 2022, 15:22
Sure... I really appreciate your help.
Thank you, dear!!
