Delivery Price Status Disable not working
viptapis
Post by viptapis » 11 Jul 2022, 15:11
Hello
as our Business format are in such way that the Shipping/Delivery price will be calculated after submitting the order.
so we try to hidden/disable the Delivery Price status. (Just price)
-> https://tinyurl.com/2oskjb8g
but after disable it, it still shows in fron (0 Zero ) price.
Would you advice how to disable it.\
Regards
Vip
Re: Delivery Price Status Disable not working
Post by aimeos » 12 Jul 2022, 06:18
For shipping options, there will be always a price calculated and if there's no price associated to the service option, 0.00 is returned. You can suppress that in the template where the price is used.
viptapis
Post by viptapis » 12 Jul 2022, 08:55
Hello
ok thanks for your reply,
one more thing,
also in the "Status" there is Review option, -> https://tinyurl.com/2ay9w7hz
do you have plan in future to add "review" for shipping option?
Regards
Vip
Post by aimeos » 13 Jul 2022, 06:55
viptapis wrote: 12 Jul 2022, 08:55 do you have plan in future to add "review" for shipping option?
What does that mean? Can you give an example of what should happen then?
