Get products by category id
peter69
Post by peter69 » 12 Jul 2022, 20:13
I want to add to the home page a carrousel of products of a specific category.
I have added the following code to packages/my-theme/templates/client/html/catalog/home/body.php:
$context = $this->context();
$products = \Aimeos_ControllerFrontend::create( $context, 'product' )
->sort( 'relevance' ) // prioritize user sorting over the sorting through relevance and category
->category( [67], 'default', 1 )
->uses( ['text'] )
->search();
However it doesn't work, I get the following error: Class "\Aimeos\Base\View\Helper\Context\Standard" not available
I made the code based on some answers I have seen in topics.
What I need is to get a list of products (with their respective image, name, price) of a certain category.
Also, is it possible to get a list of categories with their respective data?
Again thank you very much for your help,
Regards
Re: Get products by category id
Post by aimeos » 14 Jul 2022, 06:26
The context isn't available in templates for good reasons (e.g. caching) and you are not allowed to fetch data in templates. Instead, you have to create a decorator where you add additional data to the view in the data() method:
https://aimeos.org/docs/latest/frontend ... omponents/
peter69
Post by peter69 » 21 Jul 2022, 05:12
I added the following decorator: packages/my-theme/src/Client/Html/Common/Decorator/ProductsCategory.php
This is the code for ProductsCategory.php:
<?php
namespace Aimeos namespace Aimeos "Aimeos";
class ProductsCategory
    extends AimeosClientHtmlCatalogBase
    implements AimeosClientHtmlCommonClientFactoryIface
     * Sets the values of the required parameters in the view.
     * @param \AimeosBaseViewFace $view The view object that generates the HTML output.
     * @param array &$tags Resulting array for the list of tags that are associated with the output.
     * @param string|null &$expire Resulting variable for the expiration date of the output (null for no expiration)
     * @return \Aimeos "View object modified".
    public function data(\AimeosBaseViewIface $view, array &$tags = [], string &$expire = null ) : \AimeosBaseViewIface.
        $view->customParam = 'this is a test';
        return parent::data( $view, $tags, $expire );
Then to test I added
var_dump($this->get( 'customParam'));
to packages/my-theme/templates/templates/client/html/catalog/home/body.php.
But in the frontend it shows NULL.
Post by aimeos » 21 Jul 2022, 06:03
peter69
Post by peter69 » 22 Jul 2022, 05:18
I was able to implement it!
Thank you very much!
TGergo
Post by TGergo » 27 Jan 2023, 11:12
I have a simple route, controller and view on the main page.
How can I get products by category id?
I want to make carousel.
Or I can partial render CMS Cataloglist?
update:
$products = \Aimeos\Controller\Frontend::create( app( 'aimeos.context' )->get(), 'product' )
                ->category( [10] )
                ->slice( 0, 3 )
                ->search();
Post by aimeos » 30 Jan 2023, 08:46
Use the product() method of the product frontend controller:
https://github.com/aimeos/ai-controller ... #L129-L136
