add middleware for the admin panel routes
ahmed31916
Post by ahmed31916 » 13 Jul 2022, 09:29
How can I add a middleware for the admin panel routes?
Do I need to copy the admin routers in the aimeos vendor files to my web route?
ahmed31916
Re: add middleware for the admin panel routes
Post by ahmed31916 » 14 Jul 2022, 08:34
@aimeos help me please!
Post by aimeos » 14 Jul 2022, 17:23
ahmed31916
Post by ahmed31916 » 18 Jul 2022, 14:13
ok, now if I want to add a middleware for the checkout route, how can I do?
I tried to add it to this line, but shop page will affected.
https://github.com/aimeos/aimeos/blob/9 ... op.php#L38
Post by aimeos » 19 Jul 2022, 04:49
This is correct because the checkout route is part of the "default" group:
https://github.com/aimeos/aimeos-larave ... #L199-L226
ahmed31916
Post by ahmed31916 » 19 Jul 2022, 06:06
aimeos wrote: 19 Jul 2022, 04:49 This is correct because the checkout route is part of the "default" group:
Ok. that woks. But the "/shop" page affected with the middelware.
I add "auth" middleware for the route "default", now you need to login before browsing the "/shop" page.
Post by aimeos » 19 Jul 2022, 06:29
You can disable the "default" routes and add them to your ./routes/web.php with different middlewares instead.
ahmed31916
Post by ahmed31916 » 19 Jul 2022, 07:57
ok, that's good. thanks.
