Control panel blade page, doesn't loaded from the extension package
ahmed31916
Post by ahmed31916 » 24 Jul 2022, 09:15
Hello Aimeos,
I encountered a strange thing. All the blade pages loaded from the path "packages\theme1\views", except the control panel blade page. I don't know why?
This is what I did:
- In "packages\theme1\manifest.php":
	'template' => [
		'theme2' => [
			'client/jsonapi/templates' => [
				'templates/client/jsonapi',
			'client/html/templates' => [
				'templates/client/html',
			'controller/jobs/templates' => [
				'templates/controller/jobs',
		'admin/jqadm/templates' => [
			'templates/admin/jqadm',
		'admin/jsonadm/templates' => [
			'templates/admin/jsonadm',
- In "config\view.php":
    'paths' => [
        realpath(base_path('packages/theme1/views')),
Re: Control panel blade page, doesn't loaded from the extension package
Post by aimeos » 26 Jul 2022, 10:24
The templates for the admin backend can't be replaced by multiple themes at the moment. You can only have one Blade template for the admin backend, which you can overwrite at ./resources/views/vendor/shop/jqadm/index.blade.php
ahmed31916
Post by ahmed31916 » 26 Jul 2022, 11:49
Thanks for replying. The problem was from changing the path of the view of laravel (from it's config file).
But actually, I had to do this Because the Aimeos is loading the Blade files from the path "resources/views", not from "packages/theme2/views".
I tried many times to customize the html files from the package view and the jqadm from the "resources/views" but I couldn't.
ahmed31916
Post by ahmed31916 » 29 Jul 2022, 13:38
@aimeos, help me please.
