Filter products by category id
ahmed31916
Post by ahmed31916 » 06 Aug 2022, 14:08
Hello Aimeos,
Would you tell me how can I filter products by category id?
Attribute, supplier, and price filters are very clear to use. I just add f_attrid in the form and send it.
However, searching by category id need "f_catid" and "f_name"?
Why we need "f_name"!
Isn't "f_catid" enough to search?
How can I search by category just in "f_catid"?
Best Regards
Re: Filter products by category id
Post by aimeos » 08 Aug 2022, 07:06
If you use the aimeos_shop_list route (the list/search page), you can use f_catid only. For aimeos_shop_tree (the category page), you need f_catid and f_name.
ahmed31916
Post by ahmed31916 » 08 Aug 2022, 08:52
Unfortunately it does not work. It returns an error:
/en/shop
Missing required parameter for [Route: aimeos_shop_tree] [URI: {locale}/shop/{f_name}~{f_catid}] [Missing parameter: f_name].
This is my form:
<form method="GET" action="<?= airoute('aimeos_shop_list') ?>">
	<select name="f_catid">
		<?php foreach ($this->get('Model_categories') as $id => $item) : ?>
			<option value="<?= $id ?>"><?= $item->label ?></option>
		<?php endforeach ?>
	</select>
</form>
ahmed31916
Post by ahmed31916 » 09 Aug 2022, 10:12
@aimeos help me, please!
Post by aimeos » 10 Aug 2022, 11:00
Somewhere, aimeos_shop_tree is still used and for that route, you need f_name too.
Try to find out where aimeos_shop_tree is used and see if you can remove it or add the f_name parameter.
