Include the store details with each order
ahmed31916
Post by ahmed31916 » 14 Aug 2022, 19:09
Hello Aimeos,
1. How can I get the store details for each order, in the history template? it shows just the Label of the store
2. How to get product url ('order.base.product.url') in the basket template or any checkout steps? it must be exist
Re: Include the store details with each order
Post by aimeos » 16 Aug 2022, 06:58
ahmed31916 wrote: 14 Aug 2022, 19:09 1. How can I get the store details for each order, in the history template? it shows just the Label of the store
If you overwrite the account/history component class and change data() like this:
	public function data( \Aimeos\Base\View\Iface $view, array &$tags = [], string &$expire = null ) : \Aimeos\Base\View\Iface
		$view->historyItems = \Aimeos\Controller\Frontend::create( $this->context(), 'order' )
			->uses( ['product', 'locale/site', 'order/base', 'order/base/address', 'order/base/coupon', 'order/base/product', 'order/base/service'] )
			->sort( '-order.id' )
			->search();
		return parent::data( $view, $tags, $expire );
This fetches the original products including the site items for each product, so you can use in the template:
$orderProduct->getProductItem()->getSiteItem()
See: https://github.com/aimeos/ai-client-htm ... rd.php#L69
We will make that configurable so it's simply a config setting in the future.
ahmed31916 wrote: 14 Aug 2022, 19:09 2. How to get product url ('order.base.product.url') in the basket template or any checkout steps? it must be exist
You can create a decorator that fetches the original product for basket and checkout views. The original product is the only place where the URL segment is available.
Post by aimeos » 20 Aug 2022, 09:52
You can create a decorator which loops over the products in the basket you can get from the view and fetch the site items for the site IDs of the products:
$siteIds = $view->standardBasket->getProducts()->getSiteId();
$manager = \Aimeos\MShop::create( $this->context(), 'locale/site' );
$siteItems = $manager->search( $manager->filter()->add( ['locale.site.siteid' => $siteIds] ) );
