import product csv
whatdaro
import product csv
Post by whatdaro » 15 Aug 2022, 11:20
Laravel: 9.13.0
Aimeos: 2022.04
PHP: 8.1.6
DB: MariaDB 15.1
I would like to import a csv file of "default" type products but with each product having multiple attributes.
the example provides help with importing a product with a single attribute:
"attribute code","attribute type"
"S/M","size"
how would I include multiple attributes on the csv for one product. What is the format?
is it something like?:
"attribute code","attribute type","attribute2 code","attribute2 type"
"S/M","size","blue","color"
thanks
VirtualSpy
Re: import product csv
Post by VirtualSpy » 16 Aug 2022, 01:28
just do mapping for multiple attributes and on CSV heading you can use anything for your understanding like attribute 1 , attribute 2
Post by aimeos » 16 Aug 2022, 06:23
whatdaro wrote: 15 Aug 2022, 11:20 is it something like?:
Exactly :-)
