product attributes list order not working
whatdaro
Post by whatdaro » 17 Aug 2022, 12:15
Laravel: 9.13.0
Aimeos: 2022.04
PHP: 8.1.6
DB: MariaDB 15.1
I've added multiple attributes to products.
When adding these products to a "selection" product the attribute selection order is not matching to the order of the attribute's number assigned.
Could you please let me know where else is this controlled from, thanks.
VirtualSpy
Re: product attributes list order not working
Post by VirtualSpy » 17 Aug 2022, 18:12
did you assign number from 0 ?....if no you should start from 0.
whatdaro
Post by whatdaro » 17 Aug 2022, 23:16
yes, numbering starts from 0
Post by aimeos » 18 Aug 2022, 10:35
Attributes should be sorted by position and name:
https://github.com/aimeos/ai-client-htm ... p#L99-L109
Please check in that template why it doesn't work for you.
