Where to change logic of component?
oliwin4
Post by oliwin4 » 21 Aug 2022, 14:23
I try to modify home page that contains from components:
'catalog-home' => ['locale/select','basket/mini','catalog/tree','catalog/search', 'cms/page', 'catalog/filter' ]
Where to see how `cms/page` does works for home page? Where is logic of this component placed?
What if I need to change logic of
cms/page
for home component? For exmaple change which blocks to show from cms/page
Re: Where to change logic of component?
Post by aimeos » 22 Aug 2022, 06:18
You can find the logic of the cms/page component here in these classes:
https://github.com/aimeos/ai-cms-grapes ... l/Cms/Page
If you want to overwrite the logic, extend from the class in your own extension and configure the new name of your class:
https://aimeos.org/docs/latest/frontend ... omponents/
or create a decorator if possible:
