How to resuse a catalog/list component in another page?
oliwin4
Post by oliwin4 » 21 Aug 2022, 19:39
How to resuse a catalog/list component in another page (catalog home page)? Is it enought to specify the the component in shop.php config?
Re: How to resuse a catalog/list component in another page?
Post by aimeos » 22 Aug 2022, 06:24
In addition, you have to overwrite the Blade template and put it in ./resources/views/vendor/shop/catalog/home.blade.php where you have to add the code to output the header and body section for "catalog/list":
https://github.com/aimeos/aimeos-larave ... .blade.php
oliwin4
Post by oliwin4 » 24 Aug 2022, 19:35
Thank you!
