Migration of Data Rshop by RIESENIA
harpreetstpss
Post by harpreetstpss » 23 Aug 2022, 03:12
Hello Team,
I am having already an existing web application developed in some third-party PHP framework where I am using the RSHOP plugin within the existing website.
Now my new requirement is to migrate the existing website data from the RSHOP plugin to the new Aimeos framework in Laravel.
Please suggest if this data migration is feasible.
Waiting for your quick response.
Re: Migration of Data Rshop by RIESENIA
Post by aimeos » 23 Aug 2022, 05:23
Don't know. You have to see if you can map the data from the existing system to the Aimeos data structure but as both are dealing with the same kind of data, it should be feasible but the amount of work may vary.
